tonyli
Jul 06, 2024Aspirant
Orbi Satellite RBSE960B Ethernet Ports Working Intermittently
Hello, I am having a perplexing issue. I am assuming the WiFi works well- my devices on the network can always get a WiFi connection, but I have 2 devices plugged into the satellite's etherne...
- Dec 24, 2024
Just updating this, having my 960 series online, with RBS wireless and ethernet connected, anything connected behing the RBS have been stable and getting internet services. I have a couple of ethernet devices behind one RBS and serveral connected behind the other that feeds a basement residence. No issues claimed by the residence from the basement area.
FW is v.21 on my system. Working well.
Jul 06, 2024Guru - Experienced User
What devices are connected to the ethernet ports on the RBS?
Using the 1Gb ports or the 2.5Gb ports on the RBS?
What CAT# lan cable are you using? CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
tonyli
Hello. Thank you for your suggestions. I have a NAS in the 1g port and PC in the 2.5 g port. I restarted the network in the way you said. I came back a few hours later and the Ethernet connection is not working. The cables are both new cat6a. WiFi is working fine. There are no suspicious blinking lights on the orbi
