tonyli
Jul 06, 2024Aspirant
Orbi Satellite RBSE960B Ethernet Ports Working Intermittently
Hello, I am having a perplexing issue. I am assuming the WiFi works well- my devices on the network can always get a WiFi connection, but I have 2 devices plugged into the satellite's etherne...
- Dec 24, 2024
Just updating this, having my 960 series online, with RBS wireless and ethernet connected, anything connected behing the RBS have been stable and getting internet services. I have a couple of ethernet devices behind one RBS and serveral connected behind the other that feeds a basement residence. No issues claimed by the residence from the basement area.
FW is v.21 on my system. Working well.
tonyli
Hello. Thank you for your suggestions. I have a NAS in the 1g port and PC in the 2.5 g port. I restarted the network in the way you said. I came back a few hours later and the Ethernet connection is not working. The cables are both new cat6a. WiFi is working fine. There are no suspicious blinking lights on the orbi
Jul 07, 2024Guru - Experienced User
Might downgrade the system back to v.21. v.31 seems to be problematic.
RBS first, then RBR lastly...you'll need to factory reset and setup from scratch after downgrading.
- tonyliAug 10, 2024Aspirant
Could this be due to an IP address conflict somehow? It is interesting this is happening on the two wired devices plugged into the same satellite device's ethernet ports. How could I test that, and if there is a conflict, then manually assign IP addresses to the two wired devices?
Thanks.
- FURRYe38Aug 11, 2024Guru - Experienced User
- tonyliAug 20, 2024AspirantThe solution appears to be that the Synology NAS must be configured on a static IP address. This is configured in the Synology NAS settings. I Set up the PC, connected to the same Satellite, a manual IP assignment. I don’t know exactly why this worked, but it has been three days, and the devices are both working over ethernet reliably. Thank you.
