tonyli
Jul 06, 2024Aspirant
Orbi Satellite RBSE960B Ethernet Ports Working Intermittently
Hello, I am having a perplexing issue. I am assuming the WiFi works well- my devices on the network can always get a WiFi connection, but I have 2 devices plugged into the satellite's etherne...
- Dec 24, 2024
Just updating this, having my 960 series online, with RBS wireless and ethernet connected, anything connected behing the RBS have been stable and getting internet services. I have a couple of ethernet devices behind one RBS and serveral connected behind the other that feeds a basement residence. No issues claimed by the residence from the basement area.
FW is v.21 on my system. Working well.
tonyli
Dec 07, 2024Aspirant
OK the actual solution to get Ethernet ports working reliably on this satellite is to login to the router at 192.168.1.1, go to the Advanced tab, then click the Advanced button from the menu column on the left side of the screen, then click VLAN / Bridge Setup, then click to turn on "Enable VLAN / Bridge Setup". Then click "By Bridge Group", then click to enable the check boxes for Port 1, Port 2, Port 3 . For some reason it doesn't let you enable all four Ethernet Ports (only 3 out of 4), but that's fine, I just have a Synology NAS and 2 other devices connected by Ethernet cables to the ports on the back of the Orbi satellite.
- tonyliDec 10, 2024AspirantOk, even this above attempt only worked for 2 days and then all the ports stopped working again. I have downgraded the router and satellite firmware and will update this thread if I can get stability me consistent Ethernet connectivity from the satellite for more than a week
- FURRYe38Dec 10, 2024Guru - Experienced User
VLAN configuration isn't required or needed to make the RBS ethernet ports work. Normal operation should work.
v.21 Fw is most stable.
Downgrade the RBS first, then RBR lastly, the factory reset and setup from scratch using this process:
- tonyliDec 15, 2024AspirantI have given up and switched to another mesh system. nothing worked consistently
