gspeaking
Aug 01, 2021Follower
Orbi Satellite Reboot
Need help! I have the Orbi CBR750 with two satellites, one of the satellites is currently offline. Here is my dilema. This system is at my other property, in another state. I thought, once I discover...
Aug 06, 2021Guru - Experienced User
Any progress on this?
gspeaking wrote:
Need help! I have the Orbi CBR750 with two satellites, one of the satellites is currently offline. Here is my dilema. This system is at my other property, in another state. I thought, once I discovered the unit off, that if I rebooted the Cable Modem Router it would reconnect. To my dismay it did not but the other did. My question is there a way I can reboot just the non connected satellite? Thank you for any assistace in advance.
