fangruoyuan
Mar 21, 2021Guide
Orbi satellite refuse to connect
If stay in the satellite management web for long time(already log out,just not close the tab) Or if you log in serval times a day, and you may have the error “refuse to connect “ the only thing you ca...
fangruoyuan
Mar 21, 2021Guide
Two rbs850 wired, one rbs850 wireless. 192.168.1.X refuse to connect happened for the two wired rbs850.(as I said, if you stay in the page too long check devices or log in several times a day, you may see it)
Mar 21, 2021Guru - Experienced User
How long do you stay in the RBS web page?
- fangruoyuanMar 21, 2021GuideOne hour i guess.(already log out forced by the system)just not close the tab. I did check the attached devices and WiFi secured types in the page.
- FURRYe38Mar 21, 2021Guru - Experienced User
What browser are you using?
Are the RBS dynamic IP address assigned or is there a IP address reservation for the RBS?
Chrome.Edge Internet Explorer. I did the ip reservation in the first place, then remove the list and setup new. This still exists.
