Tekk
Jun 27, 2023Tutor
Orbi Satellite Status
My Orbi system with 3 satellites had been working fine for a while. Starting getting drops so I went to the app and rebooted the router. Router rebooted but all of the satellites stayed purple...
Tekk
Jun 27, 2023Tutor
It’s all hooked up correctly. Before the reboot everything showed up fine.
Everything is wired backhaul and it’s all in the correct ports. Just trying to figure out why the satellites show wired, appear to be working, but in the web interface don’t show they are connected to the router.
Jun 27, 2023Guru - Experienced User
Doesn't help us much to help you.
Please give feedback to the question presented so we can better get a idea of what's going on there so we can help you out.
- TekkJun 27, 2023Tutor
Home is 6k square feet.
Fiber comes in to ONT and then directly to the Orbi Router. From the Orbi router it goes to a TP link 2.5gb switch and is sent to each room via cat6 cable where it is directly connected to each Satellite. Each satellite is then connected to a 2.5gb TP Link to disturbed Ethernet to the devices in the rooms.
With a wired backhaul does the distance between satellites matter?
I appreciate the assistance. As I said earlier it all worked fine. Nothing has changed other than attempting to reboot the router.
- FURRYe38Jun 27, 2023Guru - Experienced User
There a model# of the TP-Link switch?
Is the cable used UTP or STP. STP is recommended.
Yes. Very important.
So the RBS report correctly if you disconnect the RBS from ethernet and let them wirelessly connect. Do they report correctly as wireless in the RBR web page and Orbi app?
Firmware is V6.3.7.10_3.3.3.
TP Link switches are SG108-M2
Cables are STP.
Satallies are probably 100 feet or more from each other. And connected with wired Backhaul.
Everything was perfect before the reboot. Nothing has changed in my plugs/gear/setup other than clicking reboot.
Thanks
