netdav
Apr 26, 2023Guide
Orbi satellite won't connect in AP mode
I have two Orbi 850 APs. The satellite connected fine when in router mode. I added a better firewall and placed my Orbi in AP mode. The problem is that the Orbi satellite will not connect/sync over w...
- Apr 30, 2023
I wanted full visibility for the wireless traffic on the Netgate firewall. It is all working now in AP mode. I still can't figure out what changed to allow the satellite tom sync wirelessly. Now that it is working I'm not too worried about it.
Apr 30, 2023Guru - Experienced User
Might try the Orbi system in Router mode and use the host routers DMZ for the RBRs IP address it gets from the host router in the DMZ.
What region are you located?
netdav
Apr 30, 2023Guide
- FURRYe38May 01, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
