mrcrowbar
Oct 06, 2021Aspirant
orbi satellites connecting to each other vs router
I have the orbi wifi 6 router with 2 satellites. My router is on main floor, 1 satellite upstairs, and other satellite in basement. My basement satellite is connecting to my upstairs satellite inst...
- Oct 08, 2021
I switched them, moved the basement one upstairs and up one down to basement. For whatever reason, this seems to have solved the issue, no clue why? Thanks all.
mrcrowbar
9Kish+ sq/ft. So I think each floor is 3K give or take. No crazy building materials I know of, built in US in I believe '09, so somewhat new.
Hard to tell exactly how far apart they are but I have them each as close to the middle of the floor they are on as I can get, and stairwells are somewhat centered on house as well so I assume that would remove some of the signal loss. If it is 30ft in a straight line, I am confident I am within bounds there. So that's what it is so odd the basement sat would connect to the top floor sat, that's definately more than 30ft away, the main router is meaningfully closer.
Oct 06, 2021Guru - Experienced User
Like Plemans mentioned, seems like placement and possible how you have them placed is causing them to Daisy Chain instead of configure in Start formation.
Try moving them farther appart and try turning them OFF and back on in sequence. I usually start with the farthest RBS first, then turn on the closer RBS lastly.
- mrcrowbarOct 08, 2021Aspirant
- FURRYe38Oct 08, 2021Guru - Experienced User
Possible how they were placed and then powered on in sequence. If the RBS are too close to each other rather than the RBR then diasy chain will take place and you see that the RBS will connect to the other RBS. Placement and distance from the RBR is key.
Enjoy. :smileywink:
