Cullercol
Feb 29, 2024Follower
Orbi satellites disconnecting from mesh simultaneously
Did you ever get to the bottom of this please.
Feb 29, 2024Guru - Experienced User
What model Orbi model# system do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Is RBS wired or wirelessly connected to the RBR?
What channel configurations are currently set on the router?
