MarkB8019
Dec 02, 2022Aspirant
Orbi satellites lost connection and will not re-connect
Hi,
Over night the other evening, all 4 of my Orbi satellites went offline and nearly all devices lost connection.
I initially tried power cycling the satellites, but they would not re-connect.
I then decided to factory reset the whole system. The main router came back online fine and I was able to set it up from scratch again. However, it will not find and sync with any of the satellites.
I tried connecting each satellite directly to my laptop in order to flash the firmware to the latest version, but could not access the web interface at all.
I then attempted to flash it via TFTP, but the connection failed each and every time.
The only way I have been able to get into the web interface for the satellites is by connecting each one to the main router with a cable and finding the IP address.
I have now factory reset each satellite and manually flashed the FW, but it still will not find any of the satellites.
I have phoned NG a number of times, but keep getting cut off.
Does anybody have any ideas at all.
What happens if you hardwire a satellite into the router and sync it?
