envirotecky
Jan 29, 2020Follower
Orbi satellites not connecting
Im ready to chuck it out the window. We had a disruption thru internet provider. When it came back up the Orbi would not work. My internet provider, Spectrum, has disruptions in service frequently ...
Jan 29, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
The RBS should auto sync to the RBR if there is a power loss. They should remain connected to the RBR if the RBR looses connection to the ISP modem...
envirotecky wrote:Im ready to chuck it out the window. We had a disruption thru internet provider. When it came back up the Orbi would not work. My internet provider, Spectrum, has disruptions in service frequently here. If I have to go thru tthis evry time, its not worth the trouble to me to spend hours trying to reconnect the Mesh network. I have tried resetting everything and finally got the Orbi router to connect. But satellites will not. suggestions???
