TomWarner97
May 12, 2024Aspirant
orbi satellites won't connecting to each other - ORBI RBR760
Hi all, I can't figure out to get my satellites to connect to each other. My router is downstairs. 1 satellite is on the first floor and 1 on the second floor. The orbi on the second floor wo...
CrimpOn
May 12, 2024Guru - Experienced User
How does the Orbi web interface Attached Devices display report the status of the two satellites?
(5G or 2.4G? "Good", "Fair", "Poor"?)
Sometimes moving the satellites around a bit improves the signal strength and changes how they connect.
Houses have so many things "hidden" inside the walls and ceilings that may interfere with the radio signals.
I would recommend powering off both satellites, then powering up the first and let it settle down before powering up the second.
TomWarner97
May 13, 2024Aspirant
They both give 2.4ghz with a green connection. But the problem is that my orbi doesnt connect to the other one. So now i only got 40mbs top
- CrimpOnMay 13, 2024Guru - Experienced User
Thank you for checking. Is this on the web interface Attached Devices or on the Orbi 'app'?
This is what my Attached Devices Connection Status looks like:
If the satellites are connected at 2.4G, that is the problem. (not which unit they have connected to).
Building materials appear to be interfering with the WiFi link between orbi units. Either they are too far apart, or the material between them is too dense for WiFi to penetrate.
- TomWarner97May 14, 2024Aspirant
So the connection changing from red to green through the day. Also the connection type from 5ghz to 2.4ghz
Both still connect to the same router and not router -> sat -> sat
