TomWarner97
May 12, 2024Aspirant
orbi satellites won't connecting to each other - ORBI RBR760
Hi all, I can't figure out to get my satellites to connect to each other. My router is downstairs. 1 satellite is on the first floor and 1 on the second floor. The orbi on the second floor wo...
TomWarner97
May 13, 2024Aspirant
They both give 2.4ghz with a green connection. But the problem is that my orbi doesnt connect to the other one. So now i only got 40mbs top
CrimpOn
May 13, 2024Guru - Experienced User
Thank you for checking. Is this on the web interface Attached Devices or on the Orbi 'app'?
This is what my Attached Devices Connection Status looks like:
If the satellites are connected at 2.4G, that is the problem. (not which unit they have connected to).
Building materials appear to be interfering with the WiFi link between orbi units. Either they are too far apart, or the material between them is too dense for WiFi to penetrate.
