TomWarner97
May 12, 2024Aspirant
orbi satellites won't connecting to each other - ORBI RBR760
Hi all, I can't figure out to get my satellites to connect to each other. My router is downstairs. 1 satellite is on the first floor and 1 on the second floor. The orbi on the second floor wo...
May 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
May 15, 2024Guru - Experienced User
