rabs13's avatar
rabs13
Follower
May 07, 2021
Orbi satellites
I have an Orbi RBK 852 WiFi 6 system and wanted to know if it's true that you can now or in the future connect other Orbi Satelittles to the WiFi 6 system that are a previous genreation (non WiFI 6). I know the speed wouldn't be the same but like the idea of still be able to boost signal.
1 Reply
  • FURRYe38's avatar
    Orbi AC RBS are not wirelessly compatible. The RBS with a Ethernet cable can be connected to Orbi AX and work using that connection method only. The RBS50Y outdoor unit can work wirelessly with Orbi AX if it's loaded with the extender version of it's FW. NGs EX series of wifi extenders also works with Orbi AX wirelessly.
