Jeremy-Boust
Nov 24, 2024Aspirant
Orbi Sattelite keep using default SSID
Hello, I have bought a new RBK853, Router in AP mode. All worked well. I have two used RBS750, that I would like to sync to the RBR850. After reset the used RBS750, sync went well, but both sat...
- Nov 24, 2024
There have been (to many to count) posts on the Community Forum describing problems when Orbi AX satellites are not on the same firmware release as the Orbi router.
I'd suggest getting everything on the same firmware release. Version 7 of the firmware introduced the IoT Network feature. You seem to have two choices:
- Update the router to v7.2.6.31 or
- Push the satellites back to v4.6.9.11
Jeremy-Boust
Thanks, It has solved the problem.
Nov 26, 2024Guru - Experienced User
If you need stable FW, v.21 is the most stable FW for the 7 and 8 series Orbi systems.
