Silvconv
Jul 22, 2021Aspirant
Orbi setup
About to convert to orbi 6 mesh. Currently have several devices operating on 2.4 ghz band. Have i understood correctly it is best to rename orbi network same as old network and same password and "h...
Jul 22, 2021Guru - Experienced User
Yes, it's recommended to use same SSID name and PW as whats used on your current router. Espeically for 2.4Ghz devices.
You can do this, first set up the new system with out it being connected to the ISP modem. You can do this with 1 wired PC. When you get it setup with same SSID name and PW, place the RBR in same location as current router. Reboot the ISP Modem or power cycle it OFF and back ON. Disconnect the old router from the ISP modem, leaving the old router still ON. Connect the new router to the ISP modem and turn it ON. Wait for the front LED to stop blinking WHITE. May see BLUE. When you see this, turn OFF the old router. Your devices should auto connect to the new router. I've done this a few times when using a new router. Works well if you use same SSID name and PW.
Silvconv
Thanks for reply. Quick follow up ques if i may. Should i get my new modem online with spectrum as a first step?
- FURRYe38Jul 22, 2021Guru - Experienced User
Yes you could. I would ask them first what they support. Spectrum does not have historical good support for user owned modems.
