Tcrus
May 03, 2020Luminary
ORBI showing connected but no WIFI, Modem going offline occasionally
Equipment: ORBI RBR850 and a CM1000 I am having WIFI connection issues. My WIFI will be great then it will drop a few times and completely go out. It shows me as connected to WIFI but there is no co...
Tcrus
May 04, 2020Luminary
I have had no drops in 24hrs
What is the size of your home? Sq Ft? 5000
What is the distance between the router and satellite(s)?
-1 satellite and distance between them 1-200ft (if I have to setup again I will use the reccomended 30feet for pairing)
-Using auto channel but I did change it while troubleshooting while it was acting up (made no difference) a couple WIFI nieghbors maybe 2-3 but are good distance apart
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s) Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings-
-These are my current settings
What happens if you disable AX Mode? I have this disablded and not seeing any drops/loss of connection (and it was yesterday I disablded this so might be a connection between my problem and AX mode)
I am almost certain this has something to do upstream since I am getting no consistantcy in errors. If this was a hardware failure or software I would get soe kind of consistancy. I will keep monitoring this amd keep this post updated if I have any changes
May 04, 2020Guru - Experienced User
200 feet is a bit too far for RBS.
30 feet is recommended starting placement distance at it's remote location. Depend upon building materials, 50-60 feet is a remote distance range for RBSs. Pairing distance can be in the same room with the RBR. Once placed, then put out at it's remote location.
I have my RBR 2nd story and RBS in the basement at about 35-40 feet in a 5000sq ft home.
