NirOnE
Sep 01, 2021Guide
Orbi shutting down with high downloads (orbi RBR750)
Hello everyone, I have a strange issue with my orbi router. Setup : Comcast modem (bridge mode) - Orbi router (with 2 satellites) - Computer (windows/Linux) connected with cable. Orbi firmware...
Sep 01, 2021Guru - Experienced User
What is the brand and model# of the ISP modem your using?
Try putting the modem into router mode again, then configure AP mode on the RBR and test the downloads.
Ya I tried on BN and Steam on mine. Nothing reproduce. I had a CM1200 at the time I tested.
If you can reproduce this with /Debug.htm debug log capture running at the time you can reproduce this, would be good to get these to NG support.
NirOnE
Sep 02, 2021Guide
my modem is : the Comcast Xfinity Technicolor CGM4140COM
Yes, my next step is configure the AP mode on the RBR. I will keep the thread updated
- FURRYe38Sep 02, 2021Guru - Experienced User
đ
- FURRYe38Sep 05, 2021Guru - Experienced User
Not sure if this will help here, however, might be worth a try...
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
