PanchoB
Mar 21, 2022Follower
Orbi speed issue
My setup now has the RBR750 router, directly off my Comcast modem. I have 3 satellites throughout the house, one of which is hardwired via CAT-5 to the main router. Off the satellite, I have a Cat-5 t...
Mar 21, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is the one RBS directly connected via ethernet to the back of the RBR or is there a LAN switch or wall outlet in between?
For ethernet cabling CAT 6 is recommended. CAT5 only supports 100Mpbs and would be limiting on wired performances.
