KeefM
Nov 07, 2022Aspirant
Orbi speed seems capped to 100mbs upload & download.
We're in Spain and just moved to a new fast broadband provider. We're getting up/download speeds off their new Huawei router (wifi) of 500mbs+. But the Orbi appears to be capped at 100ish up/down al...
Nov 07, 2022Guru - Experienced User
have you checked the wan port statistics? Maybe it is connecting at 100mbps speeds. A sketchy cat 5e cable could cause that.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
KeefM
The WAN statistics say its 100m/Full. But the port says it should be able to handle 2.5Gbs?
