HJJONES01
Apr 02, 2024Aspirant
Orbi speeds on RBS850 are much slower since switching to Fiber Internet with Nokia modem
I just upgraded to fiber internet yesterday since it recently became available. When doing the Orbi internal app speed test, it is showing over 1GB up and down. However when doing the speedtest.net a...
- Apr 24, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
HJJONES01
Apr 24, 2024Aspirant
Thanks, I did double check on the web admin app and noticed the one in my master bedroom was back to a wireless 5GHZ. Then noticed it was the same on the phone app. So I power cycled that satellite and re-synced it and it is back to wired on the two upstairs satellites again.
So I will continue to monitor it and hopefully it improves some speeds around the house on wifi.
Thanks again for all the help.
Apr 24, 2024Guru - Experienced User
Enjoy. 📡
