Fritzsche0529
Sep 10, 2020Apprentice
Orbi SpeedTest not working
Has anyone had a problem running the Orbi Speed Test from the App? I started having problems a few days after setup...it worked for several days, then stopped working. I contacted Netgear, reset th...
- Sep 28, 2020
I had tried rebooting my router and other components multiple times with no luck. I was able to contact NG support (Rose) and she suggested that I do a factory reset. She walked me through it and actually did most of the reset remotely. It was then necessary to do a new system setup for my router. Rose stayed on the line while everything rebooted. When I tried the SpeedTest upon full system startup, it worked. It has been working since last Friday. It took about an hour, and I had to clear my schedule and family's schedule to enable full shutdown of my WiFi, but in the end, everything is working great now. I hope it works for you, too.
Sep 10, 2020Guru - Experienced User
Does the speed test work from the RBRs web page under QoS use a web browser?
Does ooklas installable speed test app work from a wired PC and wireless mobile device?
Fritzsche0529
The firmware is V3.2.16.6. I have a Motorola modem through Spectrum.
