Fritzsche0529
Sep 10, 2020Apprentice
Orbi SpeedTest not working
Has anyone had a problem running the Orbi Speed Test from the App? I started having problems a few days after setup...it worked for several days, then stopped working. I contacted Netgear, reset th...
- Sep 28, 2020
I had tried rebooting my router and other components multiple times with no luck. I was able to contact NG support (Rose) and she suggested that I do a factory reset. She walked me through it and actually did most of the reset remotely. It was then necessary to do a new system setup for my router. Rose stayed on the line while everything rebooted. When I tried the SpeedTest upon full system startup, it worked. It has been working since last Friday. It took about an hour, and I had to clear my schedule and family's schedule to enable full shutdown of my WiFi, but in the end, everything is working great now. I hope it works for you, too.
Sep 10, 2020Guru - Experienced User
Does the speed test work from the RBRs web page under QoS use a web browser?
Does ooklas installable speed test app work from a wired PC and wireless mobile device?
Fritzsche0529
Ookla test works, but not the test via the app.
- Fritzsche0529Sep 10, 2020Apprentice
Modem model: Motorola E31U2V1
I have not tried the Speed Test other than through the app or via the Ookla site.
- donawaltSep 11, 2020Hero - Experienced User
Ijust tried the Speed test from the Orbi app, it worked fine for me twice. (I am on Comcast).
- FURRYe38Sep 11, 2020Guru - Experienced User
Try uninstalling the orbi app. Reboot your mobile device. Re-install the app, then run thru a NEW SETUP on the app. Then try the speed test again.
Fritzsche0529 wrote:Ookla test works, but not the test via the app.
- Fritzsche0529Sep 11, 2020Apprentice
I deleted the app, rebooted the device (iPad), reinstalled the app. I still have the same error.
- BiGMERFSep 12, 2020Apprentice
speedtest within the app is working for me.. however history will not... I mean I just got my ax6000 yesterday, however i did do about 12-15 yesterday..they where all listed then today i woke up and they are all gone.. history is blank
