Fritzsche0529
Sep 10, 2020Apprentice
Orbi SpeedTest not working
Has anyone had a problem running the Orbi Speed Test from the App? I started having problems a few days after setup...it worked for several days, then stopped working. I contacted Netgear, reset th...
- Sep 28, 2020
I had tried rebooting my router and other components multiple times with no luck. I was able to contact NG support (Rose) and she suggested that I do a factory reset. She walked me through it and actually did most of the reset remotely. It was then necessary to do a new system setup for my router. Rose stayed on the line while everything rebooted. When I tried the SpeedTest upon full system startup, it worked. It has been working since last Friday. It took about an hour, and I had to clear my schedule and family's schedule to enable full shutdown of my WiFi, but in the end, everything is working great now. I hope it works for you, too.
Fritzsche0529
Ookla test works, but not the test via the app.
Fritzsche0529
Modem model: Motorola E31U2V1
I have not tried the Speed Test other than through the app or via the Ookla site.
- donawaltSep 11, 2020Hero - Experienced User
Ijust tried the Speed test from the Orbi app, it worked fine for me twice. (I am on Comcast).
