suzimogavero
Nov 17, 2020Aspirant
Orbi SpeedTest not working
Orbi SpeedTest not working up until three weeks ago. Cannot find the issue as to why it would just stop working. Very dissapointed in Netgear as I paid top dollar for this mesh system and you would...
Neuton
Nov 20, 2020Tutor
I have the same issue. I called Netgear support, what a disappointment they are. No solution, they want me to spend my time helping them document the issue. Also, the wired and wireless speed are terrible. Meanwhile I shelled out $500 for this frustration and dissatisfaction.
Firmware: 3.2.16.6
Verizon FIOS 1Gb - Router Verizon G3100
- FURRYe38Nov 20, 2020Guru - Experienced User
What model Orbi do you have?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Is the speed test app on the router not working or is the Orbi app speed test not working?
Are you testing with a wired or wireless device?
Neuton wrote:I have the same issue. I called Netgear support, what a disappointment they are. No solution, they want me to spend my time helping them document the issue. Also, the wired and wireless speed are terrible. Meanwhile I shelled out $500 for this frustration and dissatisfaction.
Firmware: 3.2.16.6
What node is your modem working in? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Firmware: 3.2.16.6
