suzimogavero
Nov 17, 2020Aspirant
Orbi SpeedTest not working
Orbi SpeedTest not working up until three weeks ago. Cannot find the issue as to why it would just stop working. Very dissapointed in Netgear as I paid top dollar for this mesh system and you would...
Neuton
Nov 20, 2020Tutor
I have the same issue. I called Netgear support, what a disappointment they are. No solution, they want me to spend my time helping them document the issue. Also, the wired and wireless speed are terrible. Meanwhile I shelled out $500 for this frustration and dissatisfaction.
Firmware: 3.2.16.6
Verizon FIOS 1Gb - Router Verizon G3100
Nov 20, 2020Guru - Experienced User
What node is your modem working in? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Neuton wrote:I have the same issue. I called Netgear support, what a disappointment they are. No solution, they want me to spend my time helping them document the issue. Also, the wired and wireless speed are terrible. Meanwhile I shelled out $500 for this frustration and dissatisfaction.
Firmware: 3.2.16.6
