JamesAt16
Jun 17, 2020Aspirant
Orbi Ultra-Performance Mesh WiFi System RBK853 AX6000 Ethernet Backhaul with Gigabit Switch
When using a gigabit switch with the Orbi Ultra-Performance Mesh WiFi System RBK853 / AX6000, do I need a switch dedicated to the Orbi backhaul, or can I connect them into the same switch that all th...
JamesAt16
Jun 21, 2020Aspirant
The switch is a NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch (GS116NA).
Jun 21, 2020Guru - Experienced User
You should be good with this switch. V1s I don't see any green ethernet.
Give it a try and see how it goes. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
