nsharma
Apr 25, 2021Aspirant
Orbi Whole Home Tri / Dual Band Mesh WiFi 6 System compatibility with MK63 Satellite Extender
Hi, I wonder if you can please kindly help regarding the comaptibility between the Mesh WiFi 6 systems, below:- NETGEAR Orbi Whole Home Dual Band Mesh WiFi 6 System (RBK353), Router with 2 Sa...
- Apr 25, 2021
Possible it may work. The MK63 and RBK353 are dual band systems. The RBK8 series is a tri band which uses the 3rd band for wireless backhaul. I presume the Dual bands would not work on the 8 series.
Something to ask NG support to see what there offcial stance is or try the MK63 with the RBK353 system and see.
Apr 25, 2021Guru - Experienced User
