Guelfo83
Mar 11, 2022Aspirant
Orbi Wi-Fi 6 problems with Hue Sync Box
I have ongoing problems using Hue Sync Box since I have installed Orbi Wi-Fi 6 router. The sync box struggles to connect to the network and I have to factory reset it all the times. Despite the box i...
Guelfo83
Yes, it does connect to the network and to the internet. It doesn’t connect to the other device. It was working OK with another router and with this one, before they updated the router software. I have contacted the manufacturer but they didn’t bother providing a solution unfortunately. I have been made aware that other people had some issues connecting this device to a Wifi 6 router
Mar 11, 2022Guru - Experienced User
You can give this a try:
- Guelfo83Mar 11, 2022Aspirant
Thanks mate. I didn't know there was a new firmware version. I have the automatic update activated and I searched for new software yesterday but it said it was already updated. Are you aware of any issues with the new firmware?
- FURRYe38Mar 12, 2022Guru - Experienced User
Sometimes NG doesn't put release builds up on the services for notification of something new.
Users have expressed having better experiences with v.13. Mines been working well after I loaded it.
- Guelfo83Mar 12, 2022AspirantThank you. I had to manually update it. It didn’t fix the problem but it seems to be working fine. There are some issues with showing the connected devices in the orbi app, but so far so good. I think the hue box is simply incompatible with some wifi 6 routers. It works fine with Archer; it worked so and so with Linksys, but it completely struggles with Orbi for some reason. The only solution would be to buy a wifi AC extender, create a separate network and connect both Hue hub and sync box to that network.
