sjtNJ
Nov 08, 2019Guide
Orbi Wi-Fi 6 Satellites
I may be putting this in the wrong place. Simple question, how many Orbi Wi-Fi 6 satellites can I add to my Orbi Wi-Fi 6 router (it came with 1, but I need more range). Am I also able to supplement...
ekhalil
Nov 09, 2019Master
Looking into the telnet parameters, I can see that the software limit for the number of Satellites in the system is 8.
Satellites in the software are numbered sat_0 up to sat_7, so seems that this is the max number of possible connected Satellites in Orbi AX
- Chuck_MNov 09, 2019Mentor
I have added 2 x RBS-50s to my network that are hard-wired and they work great. They are fully controlled by the RBS-853 as they were in the past.
I believe that any additional RBS-50 class satellites must be hard wired as the wireless back haul is not yet compatible.
See the attached screenshot
- sjtNJNov 09, 2019GuideAwesome. Thank you guys so much for the info. Doesn’t look like the AX satellites are available quite yet, so will hang tight and use them — probably easier because I can’t hardwire some.
Again, very much appreciate the response. - luxiloidNov 12, 2019Aspirant
I have a question about syncing RBS50 to RBR850. I guess I have to press the button on each of the RBR850 and the RBS50 to make them work together. Is that through wireless signal at first? Or, can they be done just wired? Do I have to just plug them to the same network and they sync with each other?
I am asking this question since Chunk_M mentioned their back haul is not compatible with each other yet.
- FURRYe38Nov 12, 2019Guru - Experienced User
The RBS50 won't work wireless. Factory reset the RBS50 then connect via wired. They will only work wired to the AX system at the moment. Hopefully NG will get them working wirelessly in a future FW update.
luxiloid wrote:I have a question about syncing RBS50 to RBR850. I guess I have to press the button on each of the RBR850 and the RBS50 to make them work together. Is that through wireless signal at first? Or, can they be done just wired? Do I have to just plug them to the same network and they sync with each other?
