sjtNJ
Nov 08, 2019Guide
Orbi Wi-Fi 6 Satellites
I may be putting this in the wrong place. Simple question, how many Orbi Wi-Fi 6 satellites can I add to my Orbi Wi-Fi 6 router (it came with 1, but I need more range). Am I also able to supplement...
Chuck_M
Nov 09, 2019Mentor
I have added 2 x RBS-50s to my network that are hard-wired and they work great. They are fully controlled by the RBS-853 as they were in the past.
I believe that any additional RBS-50 class satellites must be hard wired as the wireless back haul is not yet compatible.
See the attached screenshot
sjtNJ
Nov 09, 2019Guide
Awesome. Thank you guys so much for the info. Doesn’t look like the AX satellites are available quite yet, so will hang tight and use them — probably easier because I can’t hardwire some.
Again, very much appreciate the response.
