Helo8787
Jun 12, 2020Initiate
Orbi Wifi 6 and Amazon Alexa (RBK853)
I am trying to sync my new amazon echos with my mesh system. I am unable to get them to link. It has something to do with the wifi security but I cannot figure out what settings will allow me to do...
Jun 12, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Good Luck.
