Helo8787
Jun 12, 2020Initiate
Orbi Wifi 6 and Amazon Alexa (RBK853)
I am trying to sync my new amazon echos with my mesh system. I am unable to get them to link. It has something to do with the wifi security but I cannot figure out what settings will allow me to do...
IronJupiter50
Jun 17, 2020Tutor
Good point. I just checked and my CTS/RTS is currently set at 2347 on 5G which is what my Echo Dot is connected to.
But I don’t know if the CTS/RTS was originally set that way when I first tried to setup my Echo Dot last Nov/Dec or I changed it after we had that firmware disconnect issue back in March.
So it’s not clear to me what fixed my problem. Or maybe I worked around it kind of like Furry did above. Maybe once it gets connected, it’ll stay connected. But for sure turning off AX mode is one way to get the Echo Dot connected.
Jun 17, 2020Guru - Experienced User
The default CTS value would have been 64. Not sure why NG is keeping this value as it seems to cause problems for some users. Changing it to 2347 seems to resolve most problems.
