Stevensa
Sep 06, 2019Tutor
Orbi WiFi 6 announced: Orbi WiFi 6 System (RBK852) AX6000
I’m a bit surprised that the dedicated link between satellites has less bandwith than my RBK50. https://www.netgear.com/orbi/rbk852.aspx
schumaku
Oct 22, 2019Guru - Experienced User
Stevensa wrote:I’m a bit surprised that the dedicated link between satellites has less bandwith than my RBK50.
What does bring up this impression?
CrimpOn
Comparing the "Tech Specs" for WiFi6 Orbi and RBR50, this impression is incorrect. Every "maximum speed" is higher on the WiFi6 Orbi, although few users are likely to achieve these speeds, even with AX compatible devices.
