cboudard
Apr 02, 2020Aspirant
Orbi Wifi 6 AP vs Router mode performance
Hello, I have an Orbi AX on the ARRIS BGW210-700 gateway for my AT&T 1GB connection. I could use the Orbi in AP mode with my Arris gateway as router or I could use the Orbi in router mode and my ...
cboudard
Thanks! A have actually kept for now my AT&T Arris gateway in router mode and the Orbi AX in AP mode. The setup took me 15 minutes with zero glitch and it work great. Apparently, a lot of people are in trouble while trying to move the Arris in Passthrough mode and use a different router instead. I still want to try it though as I like to Orbi UI much better than the Arris one. I will try to change the setup this weekend and report my findings if this could help anyone.
Apr 02, 2020Guru - Experienced User
I would do a back up configuration to file on the RBR before going to router mode. Helps save time if you want to revert back or a reset is needed.
Let us know how it goes.
