cboudard
Apr 02, 2020Aspirant
Orbi Wifi 6 AP vs Router mode performance
Hello, I have an Orbi AX on the ARRIS BGW210-700 gateway for my AT&T 1GB connection. I could use the Orbi in AP mode with my Arris gateway as router or I could use the Orbi in router mode and my ...
Zendog68
Apr 03, 2020Initiate
I have the same setup as you Att fiber(1000) Arris BG210-700 with an Orbi RBK852Arris is set to passthrough. (speedtest 994 down 984 up) A computer connected with erhernett to RBR50(router mode) gets similar speeds, Satelllite is downstairs on other side of house(approx 1900-2000 Sqft per floor), Computer connected with ethernet to RBS50 gets 359 down 35 up. I have not tried with RBR50 in AP mode. I'm mot sure if second RBS50 directly above the downstairs RBS50 will improve the speeds. Unfortunately the home was not wired with a second Ethernet run and AT&T Fiber with cable hookup prohibits the use of data and video on same wiring run(per install tech.)
- cboudardApr 04, 2020Aspirant
Thanks for your input. My topology is very similar. I moved my configuration to Arris in Passthrough and Orbi in Router mode this morning. I was surprized to see tha the Orbi is using 10.0.0.* as IP set for my local network instead of the usual 192.168.1.*. This makes me be afraid to have a double NAT and that somehow my Arris was not really in Passthrough mode. However, on the Advanced Home tab of the Orbi UI, I can see a "real" WAN address as IP address in the Internet Port section, so it looks like the AT&T IP WAN address had been correctly passed to my Orbi WAN interface. Do you experience the same?
I also thought that it might be because I kept 192.168.1.254 as IP address for the Arris and that somehow could created a conflict to be on the same subnet so the Orbi had to use a 10.0.0.* subnet. So I moved the Arris IP to 192.168.100.1 et a DHCP set of 192.168.1.254 but that didn't change anythins and the Orbi still default his IP range for local network on the 10.0.0.*.
- FURRYe38Apr 04, 2020Guru - Experienced User
After you changed and applied the 192.168.100.1 address to the modem, did you go back and manually change the RBR850 to 192.168.1.1 IP address, set the pool size, from and to, save and apply the change and reboot the RBR?
cboudard wrote:Thanks for your input. My topology is very similar. I moved my configuration to Arris in Passthrough and Orbi in Router mode this morning. I was surprized to see tha the Orbi is using 10.0.0.* as IP set for my local network instead of the usual 192.168.1.*. This makes me be afraid to have a double NAT and that somehow my Arris was not really in Passthrough mode. However, on the Advanced Home tab of the Orbi UI, I can see a "real" WAN address as IP address in the Internet Port section, so it looks like the AT&T IP WAN address had been correctly passed to my Orbi WAN interface. Do you experience the same?
Yes, I did and it works fine as far as I can see. I was just a bit concerned that I did something wrong when seeing the Orbi going by default to the 10.0.0.* net mask.
Zendog68 wrote:I have the same setup as you Att fiber(1000) Arris BG210-700 with an Orbi RBK852Arris is set to passthrough. (speedtest 994 down 984 up) A computer connected with erhernett to RBR50(router mode) gets similar speeds, Satelllite is downstairs on other side of house(approx 1900-2000 Sqft per floor), Computer connected with ethernet to RBS50 gets 359 down 35 up. I have not tried with RBR50 in AP mode. I'm mot sure if second RBS50 directly above the downstairs RBS50 will improve the speeds. Unfortunately the home was not wired with a second Ethernet run and AT&T Fiber with cable hookup prohibits the use of data and video on same wiring run(per install tech.)
