cboudard
Apr 02, 2020Aspirant
Orbi Wifi 6 AP vs Router mode performance
Hello, I have an Orbi AX on the ARRIS BGW210-700 gateway for my AT&T 1GB connection. I could use the Orbi in AP mode with my Arris gateway as router or I could use the Orbi in router mode and my ...
Zendog68
Apr 03, 2020Initiate
I have the same setup as you Att fiber(1000) Arris BG210-700 with an Orbi RBK852Arris is set to passthrough. (speedtest 994 down 984 up) A computer connected with erhernett to RBR50(router mode) gets similar speeds, Satelllite is downstairs on other side of house(approx 1900-2000 Sqft per floor), Computer connected with ethernet to RBS50 gets 359 down 35 up. I have not tried with RBR50 in AP mode. I'm mot sure if second RBS50 directly above the downstairs RBS50 will improve the speeds. Unfortunately the home was not wired with a second Ethernet run and AT&T Fiber with cable hookup prohibits the use of data and video on same wiring run(per install tech.)
Apr 04, 2020Guru - Experienced User
Zendog68 wrote:I have the same setup as you Att fiber(1000) Arris BG210-700 with an Orbi RBK852Arris is set to passthrough. (speedtest 994 down 984 up) A computer connected with erhernett to RBR50(router mode) gets similar speeds, Satelllite is downstairs on other side of house(approx 1900-2000 Sqft per floor), Computer connected with ethernet to RBS50 gets 359 down 35 up. I have not tried with RBR50 in AP mode. I'm mot sure if second RBS50 directly above the downstairs RBS50 will improve the speeds. Unfortunately the home was not wired with a second Ethernet run and AT&T Fiber with cable hookup prohibits the use of data and video on same wiring run(per install tech.)
