Dustin_V
Sep 06, 2019NETGEAR Employee Retired
Orbi WiFi 6 at IFA 2019 - 2nd Gen Mesh WiFi Is Here!
Announced at IFA 2019 in Berlin, NETGEAR Orbi WiFi 6 Ultra-Performance Whole Home Mesh WiFi System is the next evolution in Mesh WiFi. As the only Tri-Band WiFi System built with the lates...
ekhalil
Sep 10, 2019Master
theBrick89 wrote:A bit confused after I read specs on the product page. Seems like it has slower link speek on 5GHz backhaul in between the router and the satelite (1,200Mbps) compare to what RBK50 has (1,733Mbps). I wonder how this would affect the total stability and bandwidth of the backhaul
The wireless backhaul in RBK852 is 2.4 Gbps (4x4:4 / 80MHz 802.11ax) compared to 1.73 Gbps in the RBK50.
windansea
Sep 10, 2019Tutor
Will it be possible to use the existing RBS50Y outdoor satellite with the new WiFi 6 system? I understand that any non-6 satellite wouldn't offer Wi-Fi 6 speeds. In other words, will be possible to mix nodes from the current generation and this new one?
- ekhalilSep 11, 2019Master
windansea wrote:Will it be possible to use the existing RBS50Y outdoor satellite with the new WiFi 6 system? I understand that any non-6 satellite wouldn't offer Wi-Fi 6 speeds. In other words, will be possible to mix nodes from the current generation and this new one?
Wifi 6 is backward compatible, and Orbi's backhaul structure will not be changed according to the available information, so I guess that it should be possible to re-use the current generation's Orbi's Satellites with the new Orbi AX.
- StevensaSep 12, 2019Tutor
Good to know this will be compatible with my current satellites (e.g. RBW30, RBS50).
- tagteamSep 12, 2019Virtuoso
Why would anyone care about compatibility with older satellites? Just curious because it seems like a waste unless you can get a lot of WiFi6 coverage out of the router alone - assuming NG is even planning to sell the new router without a satellite (or two).
