Dustin_V
Sep 06, 2019NETGEAR Employee Retired
Orbi WiFi 6 at IFA 2019 - 2nd Gen Mesh WiFi Is Here!
Announced at IFA 2019 in Berlin, NETGEAR Orbi WiFi 6 Ultra-Performance Whole Home Mesh WiFi System is the next evolution in Mesh WiFi. As the only Tri-Band WiFi System built with the lates...
tagteam
Sep 12, 2019Virtuoso
Why would anyone care about compatibility with older satellites? Just curious because it seems like a waste unless you can get a lot of WiFi6 coverage out of the router alone - assuming NG is even planning to sell the new router without a satellite (or two).
ekhalil
Oct 24, 2019Master
tagteam wrote:Why would anyone care about compatibility with older satellites? Just curious because it seems like a waste unless you can get a lot of WiFi6 coverage out of the router alone - assuming NG is even planning to sell the new router without a satellite (or two).
Wifi 6 devices (AX) will be able to work with AC routers, so instead of throwing your old Satellites you can reuse them in areas where you can live with AC functionality/speed. I think that it’s so smart from Netgear if the old Orbi AC satellites will be possible to add to the new Orbi AX router.
- keithsplaceORBINov 23, 2019Tutor
Replying to tagteam ,
I had the same question as well . as I own a RBR50, and satellites RBW30, RBS50.
I know the 30 is only half the speed of the 50 but it used at the patio only for a few pool pals that happen by, so it's not like I'm streaming
tons of stuff there.
The RBR50 is at one end of house the RBS50 at opposite end and RBW30 is undercover porch in rear... works great.
But it would be nice to get the WiFi 6 to replace the RBR and RBS50 just for the brunt of the data streams that it gets, as majority of the Wireless devices connect to in the house, as in camera's, iPads, laptops, smart phones, DVD players, Roku etc. Then chuck the RBR50 RBW30 on eBay..
