ChristineT
Apr 07, 2021NETGEAR Employee Retired
Orbi WiFi 6 (AX) and (AXE) Frequently Asked Questions
When will Orbi support 6E?
Answer: Currently there is no release date for an Orbi WiFi 6E system, but you can find the latest information on Orbi at https://www.netgear.com/home/wifi/mesh/
Do...
ChristineT
Oct 12, 2021NETGEAR Employee Retired
Hello Orbi Community,
You may have a lot of questions about our new Quad-Band WiFi 6E Orbi Mesh System.
Check out this YouTube video: Introducing the NETGEAR Orbi WiFi 6E Mesh System (RBKE963) | Tech Overview
Here are a list of articles to learn even more!
https://kb.netgear.com/000062798/What-is-WiFi-6E
https://kb.netgear.com/000062797/What-are-the-benefits-of-WiFi-6E
https://kb.netgear.com/000062799/What-is-the-difference-between-WiFi-6-and-WiFi-6E
https://kb.netgear.com/000064250/What-is-quad-band
https://kb.netgear.com/000064249/How-is-quad-band-different-from-tri-band
https://kb.netgear.com/000064251/Do-I-need-to-have-a-WiFi-6E-router-to-use-WiFi-6E-capable-products
https://kb.netgear.com/000064252/What-are-the-key-features-of-the-RBKE960-series
https://kb.netgear.com/000060424/What-is-WPA3-and-how-does-it-work-with-my-NETGEAR-AX-router
Please feel free to create a new topic to get any other questions related to Quad-Band Orbi WiFi 6E Mesh Systems answered.
~ NETGEAR Team
Nov 19, 2022Guru - Experienced User
Compatibility across Orbi systems:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
- FURRYe38Dec 14, 2023Guru - Experienced User
Good article, information and resources on Orbi system satellites:
- FURRYe38Jan 16, 2024Guru - Experienced User
Good KB on Multi-Gig ISP and Router support information for models that support MG features:
https://kb.netgear.com/000064991/What-options-do-I-have-when-setting-up-a-multi-gig-connection
- FURRYe38Nov 04, 2024Guru - Experienced User
Here is a good tested method to access and RBS should they not correctly sync due to there firmware being mis-matched or out of date and need a manual firmware update to get them in sync with the RBRs firmware number and synced back with the RBR.
Please download the process PDF file and review the steps.
Good Luck.
