ChristineT
Apr 07, 2021NETGEAR Employee Retired
Orbi WiFi 6 (AX) and (AXE) Frequently Asked Questions
When will Orbi support 6E?
Answer: Currently there is no release date for an Orbi WiFi 6E system, but you can find the latest information on Orbi at https://www.netgear.com/home/wifi/mesh/
Do...
Dec 14, 2023Guru - Experienced User
Good article, information and resources on Orbi system satellites:
Jan 16, 2024Guru - Experienced User
Good KB on Multi-Gig ISP and Router support information for models that support MG features:
https://kb.netgear.com/000064991/What-options-do-I-have-when-setting-up-a-multi-gig-connection
- FURRYe38Nov 04, 2024Guru - Experienced User
Here is a good tested method to access and RBS should they not correctly sync due to there firmware being mis-matched or out of date and need a manual firmware update to get them in sync with the RBRs firmware number and synced back with the RBR.
Please download the process PDF file and review the steps.
Good Luck.
