jozomi38200
Jan 19, 2022Tutor
Orbi WiFi 6 AX4200 with 6 RBS 750 issues
Hi everybody i have a RBR750 with 6 RBS the house is big so i needed a wide coverage. The RBR is connected to optic fiber (900mgb download 600mgb upload). The RBR is then connected to a giga lan s...
jozomi38200
Jan 19, 2022Tutor
Hello and thx for your fast reply
V4.6.5.14 on the satellites
nope i didn't. i will do then. do i have to move them close to the RBR to do so?
i will try the speed test as you recommended and let u know the outcome
again thx
Jan 19, 2022Guru - Experienced User
If they're hardwired in, you shouldn't need to move them close to sync them
- jozomi38200Jan 19, 2022Tutor
ok i made a reset of the 2 faulty ones and now it is back to normal. i brought them close to the router and did the pairing and all good.
i will then try to fix the issue of the slow speed and let u know what are the results
thx
- plemansJan 19, 2022Guru - Experienced User
Glad that part worked!
- jozomi38200Jan 20, 2022Tutor
ok, i have did a test as follow
- i took all orbies and made a speed test connected with a cat7 cable to the satellites that were connected to the router. all giga lan
- i tested then all my rj45 in wall plug and all are giving giga lan (i renewed the house and used this Câbles Ethernet 10Gb CAT.6 A S/FTP
4P - 2x4P, LSOH-FR, 550MHz to make all ethernet plug). except 2 plugs that are giving me 100/10 instead of giga lan.It can't be the cable that is used to build the network, it can't the cat7 cable i was using to make the test.
Therefore, is it possible that is the wiring in the wall plug itself could be the issue?
thx
