EchostormFury
Oct 29, 2019Apprentice
Orbi Wifi 6 AX6000 Is a Disaster, Do NOT Buy!
I bought the Orbi Wifi 6 AX6000 kit and got it from Best Buy last week -- it is an absolute disaster! I documented my plight here: https://www.youtube.com/watch?v=zu4kB85W78c Cons No backward c...
Nsiddons
Nov 01, 2019Apprentice
I also bought the RBR852 from Best Buy on 10-24-19. I exchanged it for another RBR852 thinking there was something wrong with it. I have an RBS50Y which now doesn't work. I had to submit a ticket for all my other issues which Netgear helped me sort out. I do feel this product has some work to go, I don't think it is a disaster. This product is not ready for the novice as you must tweak every setting to get it to work right. Only my old outdoor Satellite issues remain. But a ton of good points were made by EchostormFury.
Nov 01, 2019Guru - Experienced User
Orbi AC RBSs won't work currently with Orbi AX wirlessly. Only wired RBSs will work. NG will probably make the Orbi AC RBS compatible in a future FW update.
Nsiddons wrote:I also bought the RBR852 from Best Buy on 10-24-19. I exchanged it for another RBR852 thinking there was something wrong with it. I have an RBS50Y which now doesn't work. I had to submit a ticket for all my other issues which Netgear helped me sort out. I do feel this product has some work to go, I don't think it is a disaster. This product is not ready for the novice as you must tweak every setting to get it to work right. Only my old outdoor Satellite issues remain. But a ton of good points were made by EchostormFury.
