EchostormFury
Oct 29, 2019Apprentice
Orbi Wifi 6 AX6000 Is a Disaster, Do NOT Buy!
I bought the Orbi Wifi 6 AX6000 kit and got it from Best Buy last week -- it is an absolute disaster! I documented my plight here: https://www.youtube.com/watch?v=zu4kB85W78c Cons No backward c...
GrumpyandDopey
Nov 14, 2019Aspirant
First, I'm a networking guy and wanted to replace my existing Orbi system with the new AX6000. So far:
- My CM1000 keeps power cycling after the router has booted
- Says I have internet commection (this is of course before the modem cycles) but I don't
- No backward connectivity to the old system
- No support except for this fourm.
A complete disaster.
- EchostormFuryNov 14, 2019Apprentice
So I've had some people criticize my intial thoughts and review on my video stating that this is a new hardware generation and that we should expect less from Netgear. Here's my issue about that point though:
The issue with the original Orbi was it was new tech at the time, the Orbi Wi-Fi 6 has had years of development time as it is based on the same backhaul as the previous generations, even if it needed more time for software and hardware engineering then they should have taken it. It was vaguely pitched and not transparent of Netgear of what we were even getting. Many like me were hopeful that it was at least as developed as the prior generation which Netgear should have realized that we were going to compare it against, not just other random Wi-Fi 6 routers. If it sold it as an Orbi it should live up to the Orbi feature set. You wouldn’t expect the next Xbox or PS5 to do less than the previous generation without explicitly telling you so. Likewise I bet most people who preordered like me were expecting Orbi to perform at least where the previous generation did if not more so with Wi-Fi 6. This is the review cautioning that it does not currently. I agree, once it has all the features implemented I will probably buy it again. - GrumpyandDopeyNov 15, 2019Aspirant
Some additional information:
I have 2 AX6000 Orbi routers:
RBR850 (65L19979A13FB)
RBR850 (65L1997BA1408)
With the first one
Powered down my network. Started the CM1100 then plugged the RBR850 in and went through the setup steps. 30 seconds in while trying to download the new software release, my cable modem power cycled. This happened 4 times with the same result.
With the second one. Powered down my network. Started the CM1100 then plugged the RBR850 in and went through the setup steps. It said I had internet connectivity and the modem stayed up. While trying to download the new software release, it said I did not have internet access. This happened 4 times with the same result.
I’ve been asked by support to reset the RBR850s and try again which I will do. Netgear support is totally clueless.
- FURRYe38Nov 15, 2019Guru - Experienced User
Can you manually install the FW files for the RBS and RBR after downloading them to a wired PC. After loading the RBS first then RBR, factory reset the RBS and RBR and setup from scratch.
I'll check this out this evening or this weekend with mine. I just put my CM1100 online the other night. Will be putting my RBK852 back online this evening or weekend. Depending on when I can get some time.
GrumpyandDopey wrote:Some additional information:
With the first one
- FURRYe38Nov 16, 2019Guru - Experienced User
OK, RBK852 went online about an hour ago behing my CM1100 modem. Speeds wired with a PC are 900/50. WIll see if I notice anything odd with the modem. I have rebooted the RBR a couple of times aready. I haven't seen anything as of yet.
With the first one
- GrumpyandDopeyNov 16, 2019Aspirant
OK so I finally was able to get the router and a satellite up. First I took the router I had and manually updated the software, with the cable modem down. Once I got it updated, I started the modem and was able to get internet access with one of the routers (but not the other one). I then paired the satelite and had them going, until they rebooted themselves after 40 minutes. I did this three times and have decided to give up, they are not ready for prime time.
While I had the new solution up I did a speedtest and I'm not getting the performance I was getting out of the old system
There are features I need that aren't there yet in the product, like not advertising my ssid, although they are in the prior version of the product. I've decided I'm tired of fixing Netgear's problems.
've worked at Cisco in networking, Polycom and Dell on their SDN product. If I released software and hardware like this, I would have ben fired.
Good luck and see you in a few months when the basic bugs in functionality have been worked out.
- EchostormFuryNov 16, 2019Apprentice
Yep I think it will get there eventually, but right now it is unfit for launch.
