travistyofjusti
Dec 28, 2019Follower
Orbi wifi 6 AX6000 slow wifi speeds
Router reports internet speed over 450mb/s and the orbi app's wifi analytics says my phone (Galaxy Note 10+) is getting 850mb/s from the satellite but internet speeds over wifi are 20mb/s or lower. I ...
smokedporkroast
May 10, 2020Aspirant
Any update on whether you got it solved? I just got the rbk853 set and am still having issues with anything over 160mbps for my ftp.
I cant tell if its the computer or the router that is causing the slowdown, but the computer has an intel ax200 which has has 2 channels capable of 2400mbps, Im consistently getting 160mbps max.
May 11, 2020Guru - Experienced User
What are your wired speeds to your ISP service or to a speed test server using Ooklas installable Speedtest app?
FTP usually won't have high speeds due to it's design nature. Similar to VPN, the the processing that is being handled, tests to slow speeds down using these protocols.
smokedporkroast wrote:Any update on whether you got it solved? I just got the rbk853 set and am still having issues with anything over 160mbps for my ftp.
- smokedporkroastMay 11, 2020Aspirant
My isp speeds ar 75/13.5, though its irrelevant since everything is over LAN, the WAN connection speeds are fine when i connect to the ftp from another location. What bothers me is when Im at home with a direct connection less than 2ft from the router and I only get 160mbps.
Thanks
Forgot to mention, when I plug into the router with cat6, I get ~600mbps to the ftp. The ftp server is abut 200ft from the router connected via cat6.
- FURRYe38May 11, 2020Guru - Experienced User
What connection rate is the wireless adapter connecting at?
