KRYPTONITE
May 28, 2020Aspirant
ORBI WIFI 6 AX6000
I WANT TO SETUP 8 OF THESE. CAN I ADD 7 SATELLITE TO A SINGLE NETWORK SYSTEM. IF SO, I WANT TO SETUP 4 OF THOSE THROUGH ETHERNET BACK HAUL AND 4 OF THOSE WITH WIRELESS BACKHAUL. WHAT ARE MY OPTIONS?
KRYPTONITE
the thing is where i live the walls are concrete and vry very thick, think of a bunker and sometimes the wifi signals completely drop once i close the doors to a room where the satellite is kept so thats why i need so many of them. currently i have the older orbi system and face this problem so i was wondering whether the new wifi 6 models can do more then 3 satellites because my current setup doesnt work with 4 and i end up with three different wifi networks across all my floors and 2 different per floor. so it sucks.
May 28, 2020Guru - Experienced User
You may want to just run ethernet or power line adapters if needed and setup all RBS wired. Concrete and steel will always have an impact on any wifi system. AX or otherwise.
- kildareMay 28, 2020Luminary
I'm not sure you can add up to 7 satellites to the current Orbi AX6000 implementation.
Even the business system Orbi Pro AC3000 can have up to 6 satellites:
Larger space? No problem. Orbi Pro’s got it covered
Extend your WiFi range further than before. Add up to 6 satellites to the Orbi Pro Router.
https://www.netgear.com/orbi-pro/default.aspxBetter check with the Netgear support.
