peachair
Dec 19, 2020Aspirant
Orbi WiFi 6 Cable Modem Router / CBR750 - Blinking Downlink Light
I recently purchased an Orbi CBR750 Cable modem / Router. It installed ok it seems, and the ISP says they see it on their system and everything should be good. However, the downlink light (seco...
Dec 19, 2020Guru - Experienced User
do you have a screen snip of the cable connections page and event logs? that helps us take a look at the line
