y1uto
Dec 19, 2022Follower
Orbi wifi 6 can't connect to the internet
Just brought the Orbi Dual Band Mesh WiFi 6 System and while everything works in terms of connection to the router via devices and satellites. I cannot connect to the internet. I get an error message...
Dec 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices are you trying to get internet on?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
