cperry92
Jan 18, 2020Follower
Orbi wifi 6 compatibility
Orbi wifi 6 compatibility Just upgradedt the orbi router with wifi 6 (package has router and satellite RBK852. At best buy they also sol me the outdoor satelliite and some plug ins. Apparently they...
Jan 18, 2020Guru - Experienced User
THe outdoor RBS was supposidly to work with Orbi AX. Seems that some users are experiencing otherwise.
You can disable AX mode on the RBR and see if this helps with getting your devices connected...
- Chuck_MJan 20, 2020Mentor
I recommend you check your printer for current firmware and drivers.
